V198 PRO DRONE, SD card
Hi new on here so hope i get this post correct, am I right in thinking the V198 does not take an SD card ?
TYIA jeff
The V198 Pro (or V198 Max) drone requires a microSD memory card (Class 10, U3, V30 rated) with a recommended capacity of 32GB to 128GB to properly handle its high-definition video recording without dropping frames.
Great thank you , I can seem to find a slot for one though ???
On the V198 Max / V198 GPS drone package, the memory card slot is located on the bottom edge of the remote controller (right next to the charging socket and data cable port), rather than on the drone body itself. Hope this helps :slight_smile:
Hi Paul thank you for your reply, there is only a charging port on the controler no SD slot or dats port ???
Best regards Jeff
Hi, Sorry I can’t be any more help other than the reply earlier. :- :frowning_face_with_open_mouth: Hope you find a solution.
Regards Paul
