RTK Base station advice
Hi all,
Im after some advice on budget rtk base station options for use with a mavic 3t, any help would be great.
I was looking at the same problem, in the end I went for a DJI D-RTK3 and Tripod, came to around £1500 - this is pretty much the cheapest you go (even looking at used) without building your own from bits, is plug and play, comes with tilt compensation which is handy as its also a rover, finally as its all the same ecosystem you dont end up second guessing the setup - which is worth the money over some unknown.
