Propeller Question/Clarification
I have a couple of questions regarding Propellers:
First how I understand it, props have a size 10" say that is the space it needs to spin, in simple terms. They also have a pitch, whish is the angle of the blade against the Horizontal plane, say 5, often combined as 1050/3. The 3 being the number of blades.
So If I have that correct, if not I’m sure someone will advise/correct me, hence the clarification bit… here’s the questions
Which is better of the following two? and why? so I can understand.
1050/3
1070/3
EDIT - I realise the question above is not necessarily the best in the way it’s phrased, I believe it would have been better in this form - What are the differences in performance between the two props?
TIA
Well it appears everyones friend Google has struck again, I found this useful peice:
Drone Propeller Types Explained:Key Differences
Were you able to get this sorted?
Sort of mate, the question was about me understanding the differences in the props, the link I added seems to explain what they are and how they work.
Which now makes sense as it’s the same principle as those on boats that I had years ago. Not the same pitch prop on a speed boat as on a tug!
