Need help with avata 2
I have my avata 2 set to record from takeoff this is not happening. Has anyone had this issue. Help would be appreciated.
@Geordielad Hiya :waving_hand: Have you enabled the auto Record on the takeoff setting?
Hope this helps :wink::+1:
Yes. It’s always been set like that. But for some reason it went off.
@Geordielad Have you checked your firmware or you could have a slow or faulty micro sd card?
