Gimbal/Camera Issue
Hey, I’m really hoping someone can help me with my DJI Mini 2 drone. Lately, whenever I fly it, the gimbal doesn’t seem to work properly. It keeps jolting or getting stuck, and I have to readjust it several times, even when there’s very little wind or the sky is completely clear. Is that normal?
As for the freezing and poor video quality, I know that’s caused by the SD card, so I’ll be getting a new one very soon.
It’s going to sound obvious, but have you taken the gimbal cover off?
Have you tried to calibrate it? also check the rubber vibration dampener too.
Yeah I always take it off before flying it
I haven’t tried it yet, but I’ll have a look into it
@BrXd_XD Hi Brad :waving_hand: Have you checked for debris or grit around the camera and restart calibrate the gimbal in the DJI fly app?
If this does not work you may have a damaged or torn ribbon cable this is caused by crash damage if you have had a crash recently.
Or sometimes leaving a ND filter on from a third-party may causing the gimbal to struggle.
I hope this may have helped you :wink::+1:
have you switched on with the cover on the camera. if you have send it in for repair
