Hi, everyone. Help requested . I have an Air2S, with an RC. I’m looking for a shade for the RC itself as its hard to read in bright sunlight. Has anyone with the same controller found a solution?
@FiveByFive Hello John ![]()
I found this sun Hood shade protector for the DJI RC controller on Amazon for you. This may help to reduce the sun glare on your RC controller.
Here is the Link.
Thanks for that. Appreciated. I’ve also just realised that my photochromic specs weren’t helping.![]()
I’ll report back with a product review in due course.
@FiveByFive You’re most welcome ![]()
That link is not the UK site.
This one is a UK version.
I 3D printed my own, not used it yet though, all these controller add ons are a pita at times.
@Mattylad
Does it really matter if the link was not for the uk, Considering it’s exactly the same thing and cheaper from the US?
I had the same issue. A foldable sun hood made specifically for the DJI RC works well and cuts glare significantly loads on Amazon. You could also fit a matte anti-glare screen protector, which helps reduce reflections in bright sunlight. Using both together makes a noticeable difference on sunny days.
