I ordered the above from Amazon 2 weeks ago to use whilst learning. They arrived today and they are “apparently” genuine DJI ones although it never stated when I purchased. I have put them on and flown indoors,(although at first I forgot to take the gimbal cover off, oops!!) I say “apparently” because there don’t seem to be any listed for the mini 4 on the DJI website. It seems to fit okay
Seem to be a lot of those advertised and can cause potential problems:
Mini 4 Pro does not have any obstacle avoidance function after installing the blade protector, and it can’t go around or brake when encountering obstacles; when using the intelligent flight function, the aircraft also has no obstacle avoidance ability.
After installing the blade protector, the weight of the aircraft will be more than 250 grams, some countries and regions may need to obtain the appropriate license, please carefully understand and comply with local laws and regulations before flying.
Thank you for the advice Westbury. I am aware but it’s just while I’m learning to fly properly.
I appreciate new flyers think they need prop guards but if you’re flying that close to obstacles to need them, the only experience you will have is crashing.
