Hi all had a slight accident with this it got blown into a tree managed to get it out but it fell in the river
but I sat it in a box of rice sealed for a few days and all seems good
leave it for a week some were hot. you took the battery out. the battery almost defgone. after a week pop new battery in “outside” if it work ok if it don’t o well.
Good luck !
Hope it works…
As @flyers said. Battery is the dangerous bit. Everything else and a box of rice is usually a good save!
is there a update how did it go ???
Yes all working fine used hairdryer on medium heat to blow through the drone and battery in a cup of rice did the trick
Huzzah! Maybe stick clear of trees and large bodies of water for a bit! ![]()
