Information please, how do you request a link to complete c of c theory test before taking on the practical test. Any information would be appreciated
Who are you doing your A2 CoC with? They should be able to assist you. I used Coptrz and would recommend them if you are casting around for a suitable company. I recall that I was unclear as to how and when was supposed to upload my practical details and once they had explained the process I realised how it worked. It was very easy.
IIRC there is no time limit and you can do each section as and when you are ready. You only sit the actual exam after all your details have been uploaded and approved and you feel comfortable with sitting it. I must have done a couple of dozen mocks before I felt ready!
@ctdroneman Thankyou for your reply.
The c of c am referring to is the fpvuk one.
Which is in your membership section. I have reached out to a local examiner at this moment in time there is no reply. However it does state to complete theory test before practical. I assume there is the link I can access to complete theory prior before moving on to the next stage.
I appreciate that took the time out to answer me.
Best regards. fisherman
With Coptrz a link is provided once you have completed the theory modules. I would think that others are similar.
However, this wasn’t explained earlier in the course and, like you, I was left wondering.
Yes i agree with you. If isn’t set out clear enough to read an understand to follow basic instructions how are people meant to succeed Flourish with Confidence.
I may email fpvuk to find more information an understand the correct path to take on this matter.
Once again thankyou for your input.
This shows you what the practical comprises of - https://fpvuk.org/files/FPV-UK-Certificate-of-Competency-Practical-Member-Notes-April-2024.pdf.
I don’t think there is a theory as such, maybe just go through the document and practice the manoeuvres.
