Best Flight Simulator
I’ve got my flyer ID and Operator ID
My drone is a DJI Lito x1
DJI RC-2 controller
I’m nervous about first flight as have no experience with controllers or gaming consoles etc
What’s the best way to practice is their a flight simulator where I can use the DJI Controller and practice without actually flying my drone. Just some practice?
Any suggestions much appreciated as a few out there but not sure which is best
There is a flight simulator built in to the RC-2 controller including some basic lessons as well as free to fly zones .
Don’t worry too much about your first flight. DJI drones are very stable, if you let go of the controls the drone will just stay there in hover.
I don’t believe the RC-2 can be used as a controller to FPV (First Person View) online sims. You need the DJI FPV Remote Controller for that. The two sims I use with that controller are Skydive and Uncrashed.
The inbuilt sim on the RC-2 should be enough to get you going.
The flight simulator within the RC2 controller is all you need to get an idea of the controls. DJI camera drones are very easy to operate because if you panic you can let go of the sticks and the drone will hover in place. If you want something to read and follow for your first flight then check out FPVUK’s practical flight test - https://fpvuk.org/files/FPV-UK-Certificate-of-Competency-Practical-Member-Notes-April-2024.pdf. It should give you some handy pointers.
I don’t think flying simulators is much like flying drones.
I started out using one for FPV, to memorise the controls, but after a year I decided that real flying is nothing like simulators.
I think they simplify the physics to make the games more playable.
Can you really launch a micro quad off a skyscraper roof? Or fly in rain? Or fly around an entirely windless landscape for hours on end on one battery?
Totally agree! Sims for FPV is a must to just gain an understanding of the mechanics/physics of a quad and how the controls affect it :+1:t2::+1:t2:
For learning the basics of FPV manual flying sims are a useful tool. Saves on the amount of crashes !
The physics is improving in the sims . Even batteries these days…
Yes, they’re games first and foremost.
Some earlier ones had a training section, but they don’t often cover much.
When I actually got an FPV, I had to re-learn pretty much everything.
Hehe yeah even after 8-10 hours in the sim flying an actual quad felt very different!
I still find sims pretty helpful to learn tricks though.
I’ve done tens of hours.
I think having muscle memory for key flight controls and manoeuvres is a big help with FPV, and even camera drone flying. So sims are definitely good for that.
The one thing I would like to learn is how to graciously accept when my drone has failed to take off properly for the fifth outing in a row! Or the reality that I probably fly half of my flights compensating for something I’ve set up incorrectly in Betaflight.
I like to bando, but the thing about flying in tight spaces is that your eyes need to be familiar with the lens you’re using, to properly gauge how much space you have. I’ve had to practice a lot when changing lenses as they totally throw my spatial awareness.
For some reason my spatial awareness is much better IRL than in sims. And IRL I had to learn takeoff, landing and braking as these are not covered in sims, which are usually race-oriented.
Anyway, I second the RC2 sim suggestion.
It comes as close to FPV as you can with the Avata (although afaik it doesn’t work with goggles) and it replicates a lot of standard DJI controls so you can practice focus tracking and all the flight modes.
If anyone has managed to land on one of those moving trucks, I need to know about it!
I use Velocidrone for practice. It’s oriented around racers, but that doesn’t stop me using it for freestyle practice.
The simulation is anything but simple, going as far as simulating propeller deformation and it’s effect on thrust when you punch the throttle. It simulates battery mass and it’s effect on quad handling as well as how lower LiPo voltage effects throttle.
(The battery voltage side of the sim wants some work IMO. It’s a tricky one though as modern BetaFlight versions can compensate for voltage sag quite well, so it’s not as much of a ‘thing’ as it used to be.)
It has a range of different props that can be simulated on the larger (5"+) quads, along with the other adjustable parameters I can set up a quad to match my real world 5" basher with astonishing accuracy.
It’s not exactly the same, but it’s good enough to be able to learn silly maneuvers like trippy spins and matty flips, to hone the stick adjustments required to not write off a stack of £450 quads learning it in the real world.
I realise that this discussion is centred around DJI quads, but if that’s as far as you look, you’re not going to find much. DJI wall their garden off very well :wink:
Good point.
I was really attracted to Velocidrone for the reasons you mention but then I went on Steam and got dazzled by the looks of Tryp FPV and the knockdown prices of Liftoff Micro Drones and Uncrashed.
Now I think about it, I still want to give it a go. The graphics were designed for GPUs from four generations ago, which means it looks like a cartoon, but maybe it will run on my 2018 laptop, which I always have with me? And a current GPU would surely toss those pixels around pretty effortlessly while doing other things at the same time.
My biggest concern was with the physics. The marketing focuses on the physics of the drones, which is great by itself, but drones don’t fly in a perfect windless environment (alright, they do more or less that in stadium races) - they handle differently in thick, cold air, perform differently at altitude, get tossed around by winds or downdrafts near buildings etc. and I don’t see any mention of environmental factors on their site.
Still, if it’s fast and fun, it might be the thing for me. And it’s only £16.99.
I have realised as a complete beginner I just need a lot of hours in, just on basic manoeuvring learning the basics.
Im trying not to do the usual everything all at once too soon.
I realise I just dont have the basic grasp of the controls.
Its nice to have a new challenge, stepping outside of the work and family bubble !
Good luck with that.
I was sitting on a bench in the park today flying happy as Larry and then my family bubble turned up, and then the dog, and then a random but very nice lady with a dog, and I managed five more minutes before I realised that three people were talking at me at the same time and I had to land or a crash was imminent!
:joy::joy:
I’ve flown 2 times
1st within 10min man and dog arrive and start chatting so bought it down.
2nd
After 15min a guy came around a corner of the building phone in hand and was clearly looking to see who was flying the drone have me a dirty look and went away
I’ve notice a lot of people just don’t like drones and think your spying or something it’s odd to me.
Guess you just have to put up with these things so long as I’m legal I don’t care :joy:
I get the man and dog thing all the time. Trouble is I’m as interested in dogs as they are in drones so I almost always have to land.
That’s what you get when you have too many interests!
