Have ordered a 4th Mini 4 Pro battery from DJI.
Regarding charging.
The charging plug I have has a stand USB port and a USB C port. I connect the standard USB port to my DJI 3 battery charger. But hoping that at the same time I can use a USB-C to USB-C cable to charge a 4th battery in the drone?
On a side note. If I use the USB-C to USB_C port and cable to charge the remote the charging lights flash across much faster than when using the standard USB to USB-C port and cable? Is this doping any damage please?
