Maybe A Dumb Question
This may be a dumb question, I’m new to all of this so don’t crucify me please.
I live in a no fly zone (it’s on the edge of a military fly air base ) would I be able to use my drone for practicing flying maneuvers in my garden ie takeoff up to eye level and moving to the left and right then landing etc. Basically getting used to how the drone and controller works. Or do I have to travel around half an hour away to a safe area.
No need to apologise at all it’s a perfectly reasonable question, especially when you’re new to flying drones.
If you’re within a restricted/no-fly (AREA/ZONE) because of the nearby military airbase, I would recommend checking the applicable restrictions before taking off, even if you’re only flying in your own garden and staying at eye level. The fact that the drone is low and only being used for basic practice doesn’t necessarily mean the restriction doesn’t apply.
It’s always better to be on the safe side, so if you’re unsure, checking the official airspace restrictions or contacting the relevant authority would be the best option. Otherwise, travelling to an area where you’re definitely permitted to fly would give you peace of mind while you practise. Happy Flying
That’s a tough one!
If it’s any consolation, our place was between two major RAF bases until recently, when one of them closed.
You can learn flight basics safely in a simulator.
If it’s a DJI, you will learn that stuff quickly because every flight maneovre is at least partly automated, and then you can move on to basic flying on the same day.
Another reason to potentially avoid flying near the base is that they generate a lot of RF interference that might significantly reduce your radio range.
I find just flying near a built up area reduces my range by around 80%.
