Hey Guy’s. New to the drone game & just purchased a Avata 2 fly smart combo with goggles 3.
My question is, do I need a sim as the drone itself has a built in memory & I’m only doing a bit of filming here & there. Cheers
It has a 45gig internal storage. This requires offloading from the drone to a computer rather than swapping a card and continue flying.
Depends on what you want. Some people may want to swap cards and offload when you swap battery’s. Some will be fine with drone offload at the end of a flying session. The latter being more risky if you have a flyaway.
You will want a card for the goggles for the FCC mod, if you want to go that way
J
Why would you want the FCC mod in the UK which would make the drone illegal and probably void your insurance ?
There have been convictions for doing this mod.
The line of sight rule means we have more than ample range anyway.
You’ll probably find you’ll need some extra storage above and beyond what’s in the Avata 2 at some point.
Here’s a list of DJI approved microSD cards for that drone:
SanDisk Extreme PRO 32GB U3 A1 V30 microSDHC
Lexar Professional 1066x 64GB U3 A2 V30 microSDXC
Lexar Professional 1066x 128GB U3 A2 V30 microSDXC
Lexar Professional 1066x 256GB U3 A2 V30 microSDXC
Lexar Professional 1066x 512GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 64GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC
Kingston CANVAS React Plus 64GB U3 A1 V90 microSDXC
Kingston CANVAS React Plus 128GB U3 A1 V90 microSDXC
Kingston CANVAS React Plus 256GB U3 A1 V90 microSDXC
Samsung EVO Plus 512GB U3 A2 V30 microSDXC
wow, yes you are correct… good thing I haven’t done it.
If you’re not going to do much filming or photos and you’re not using the max possible quality settings you might be able to get away with not using a memory card. My recommendation is to have a test flight to simulate how much you would film and take photos and see how close you get to filling up the internal storage. If you get close, buy a memory card. It also depends on whether or not you’re happy to download the footage into your computer after every flight.
The list of memory cards on the DJI website is just a list of recommendations, you don’t need to get any of them specifically. All that matters is that the card has fast enough write speeds. Look for MicroSD cards that have the A2 V30 specs. You should be fine with anything that can write at 150MB/s or higher.
I got a 256Gb Sandisk Extreme Pro from Amazon which has a write speed of up to 170MB/s but is generally cheaper than the stuff recommended on DJI’s website.
