Article 16: Can someone Explain?
Must apologise I have no experience of posting on any ! Of the social media and group chats club hubs etc.
Hope this get posted in the correct section?
Still not flown yet :grin: got everything in place and looking for places to fly in my area.
Came across Article 16
Can someone explain? Is it permission for members to fly in some restricted zones or am I getting confused?
Do I have to register separately for it ?
Have Flyers ID Operator ID Insurance etc.
Reading so much about the drone subject it’s a bit overwhelming all the info and documents
If someone could explain in simple terms what it is ?
I’d be grateful
Hello,
Article 16 is something you can fly under once you’re a member of FPVUK. It part of the benefits they offer, so no need to sign up to it separately.
In its simplest form it’s an alternative to doing the A2CofC, but still doesn’t quite give you the same freedoms (but also some different ones). It’s only for recreational flyers and you can see all the benefits here - CAA issues Article 16 Operational Authorisation - FPV UK.
Free feel to ask anymore questions if something doesn’t make sense :+1:t2:
Move from the ā€œFor Saleā€ section :wink:
Thanks for that :+1:
Hi Good morning
As a new FPV UK member and completely inexperienced in hours of flight time.
I wanted to ask
I have a DJI Lito X1 it came with 3 Plus Batteries which would take it well over the 250g even outside the seemingly acceptable weight tolerance.
My question is under article 16 am i still able to fly it so long as its flown with manual control and not flown using any of the automatic flight functions.
Would this also apply to a DJI Mini 5 with the DJI plus batteries.
I’d appreciate more experienced member comments. !
Thank you
You can still fly the drone within and outside of Article 16, but as far as I’m aware Article 16 still doesn’t give you permission to fly where there are no-fly zones such as near airports and where there are bylaws or private land without permission from owners.
When it comes to UK regulations the sub 250g category ends up being pretty irrelevant the moment the drone has a camera capable of taking photos and videos, which pretty most drones do.
Thanks for that
I read in a previous post that there is a margin in the weight of the drone above the 249g due to manufacturing tolerance.
But in my case the Lito X1 with the Plus Battery it takes it well above that.
As I read in the Article 16 it’s allowed over that weight but manual flight only other than RTH and Obstacle Avoidance
It gets a bit confusing and just wanted to understand and keep legal.
Thanks again for taking time to reply.
I’m finding a lot of places I thought would be a good spot aren’t :weary_face::weary_face:
It’s a learning process which I’ll get a grip of eventually :man_shrugging::+1:
Article 16 does give you some more allowances in terms of what is possible (I forget what they are), but as you’ve said you are required to operate the drone manually and you are also required to perform a risk assessment before the flight.
I wouldn’t worry too much about the weight of your drone with the Plus batteries. It puts your drone in the UK1 category which is pretty much the same category as a sub 250g drone with a camera. It’s only when the weight of your drone starts to get to over 900g (I think) or so that you then start getting additional restrictions. In other countries this can change, but then again you can’t really use Article 16 when abroad as far as I know.
Someone please correct me if I’m wrong. And if I’m honest there is an actual chance that I’m wrong :sweat_smile: There are so many different regulations and gotchas to navigate that it all becomes blurry
This video might help: https://www.youtube.com/watch?v=RhQWmlUhoxE
It’s an interview with FPV UK’s Simon Dale.
There are a few other videos on that channel specifically about Article 16 and regulations in the UK that are also worth a watch.
Thank you I will take a look at the videos.
Using a plus battery in a Lito X1 removes its C/UK label making it a legacy aircraft unless it has a C1/UK1 label on it. If it is a legacy aircraft then article 16 allows you fly in the same sort of areas as the A1 open category (parks, residential, commercial) but you need to keep a 30 metre distance. If you use the standard battery so it’s under 250g then you can fly in the A1 category with the most amount of freedom.
If your drone has a UK1 or C1 label on it then you don’t need to worry about article 16 when using the plus battery as you can fly it in the A1 sub category with the most amount of freedom as the law changed in January this year.
It’s only a C1/UK1 if it has the correct label. You can’t just add weight upto the 900g limit and say it’s a C1/UK1 drone. If a drone has a C0/UK0 label on it and you put a plus battery in it then it is classed as a legacy drone, therefore flight only in the A3 sub category unless you have article 16 or an A2CofC.
Sorry if I’ve misinterpreted what you’ve said, but quite a lot of people get confused by this!
It’s is confusing as a complete beginner to drones and the CAA rules
As i understand it’s over weight with the plus batteries in.
However as a member of FVPUk and If i fly within the rules or conditions of article 16 I’m still ok to fly my drone.
Within those limitations.
I hope Im correct !:man_shrugging:
I found the template on FVPuK website for pre flight risk assessment and I’m as confident as I can be thats the case.
These things are complex and to a novice confusing.
Im very grateful to have this Drone Hub platform to ask more experienced drone enthusiast.
Yes that’s correct.
It’s worth checking though. Did you buy the drone as a fly more package with the plus batteries, or did you buy the plus batteries separately after you bought the drone?
I bought the drone and batteries as a package deal direct from DJI store.
In that case look on the bottom or back of the drone and does it say UK0 or UK1?
It says UK0 ?
Hmmm that’s weird. If you ordered the Lito X1 Fly More Combo Plus then it should have a UK1 label. I’m not sure where it would be but can you see the model number, is would be DGP14C or DGP14D?
It might be worth speaking to DJI tomorrow as something isn’t adding up.
If it was labeled UK1 then you can fly in the A1 sub category and not have to worry about article 16, so it’s worth finding out.
My apologies my DJI LITO X1 is labelled 1 Uk1 came with plus batteries
I have a mini 5 pro labelled 0 UK0 came with plus batteries.
It’s very confusing classification, CAA, Article 16! Conditions / exemptions etc
Think I need to go lay down in a dark room :weary_face::weary_face:
When I purchased the drones and the package deal which included the plus batteries i didn’t know of possible implications of having the plus batteries
Essentially I want to fly and take videos and pictures etc for purely recreational purposes.
Within the law.
I’ve no idea if in practice and my drone was seized if it would be clear to anyone who might check.
I’m possibly over thinking it ?
Do you know how I could get clarification of the legallity of my drones and plus batteries?
Yeah it can all get quite confusing, but good news - as your Lito X1 has a UK1 label you can fly it in the A1 sub category with the plus batteries and you don’t need to worry about article 16.
So, fly it in residential, commercial or recreational areas with no minimum distance to uninvolved people, just don’t fly over crowds and check something like The Drone Map to ensure there aren’t any airspace restrictions (airports, prisons etc). Also make sure you have an Operator ID and flyer ID. Insurance isn’t mandatory for recreational flying but it’s recommended. Although as you’re a member of FPVUK then you have insurance through your membership.
As for the Mini 5 Pro, if you bought it as a fly more combo with the plus batteries then I’d query that with DJI as it should also have a UK1 label.
